mrivera77524
Amigos,
First question is what is good compression for this motor at sea level? AI/google giving me two different answers, the first being 80-90 and the other being 90-105. So, what IS the right answer?
Second, at higher elevation should compression read lower? I've spoken to a racecar mechanic in my town that says "yes, you'll lose 15% compression due to our elevation" and the internet says multiply the regular compression by 86% and that'll give you your compression at this high, which is pretty much 15% less. Other mechanics have told me elevation doesnt matter.
The motor im looking at reads 75psi on both cylinders and I DID NOT have the throttle open. Didnt learn about that until this morning after I tested it. Thank you in advance for the help.
Marcos
Marcos
