jakethebrake99
"This motor will get out of th
"This motor will get out of the hole smoothly, and run ok to about 1/2 throttle. When I try to give it more throttle, it does not respond with any more power, but will start to miss and shake, until I back off to about 1/2 throttle and it will be smooth again. Compression check was good in all cylinders, carbs were rebuilt, plugs were replaced, seems to get good spark with the tester. Any Ideas what might be causing this problem?? Thanks."
