Hello
I am new to the forum and fairly new to diagnosing outboard problems so please let me know if this topic has been covered in another thread.
While on the water recently my motor seemed sluggish on the whole shot...didn't want to jump up on plane. This 100 horse johnson is on a 17' MayCraft so this shouldn't be the case.
So i went home and hooked up the muffs and pulled the air intake off so to spray some carb cleaner to try and clear jets. When I sprayed the cleaner into the top carb, the motor bogged down briefly as usual. But when I sprayed into the lower carb there was no change in the engine. I assume this means blocked jets?
Also, it appears that fuel was being spit out of a needle on top of the carb (bleed valve possibly) and was draining out of the bottom of the motor and down the shaft cowling.
Should a rebuild fix this issue?
Thank you for any help
