So I replaced the stator from CDI, trigger same, got a newer flywheel, it wasn't getting spark on 3 and 4 before. So after that there is spark on all 4, I checked DVA on the stator 1-2 and 3-4 360ohms and 200V per their specs. I get spark at the wires, trigger gets 1.2V between 1-2, 2-3 and 3-4 so all good there. The carbs are rebuilt I get fuels to them but the priming bulb is sometime not firm even though it is new. There is gas on the top also, pulled off the hose going top and I get gas when cranking. I cannot get it to fire up. Just cranks and no explosion to get it started. I did remove the br/yel stop wires to make sure. I have 130x2 and 125x2 compressions. Need some advice. Thanks
