jersey bob
I wish I was at the stage that I could contribute to this forum, instead of asking for help, but help I still need. 1st issue, is there supposed to be water spraying out of the small passage on either side of the joint between the lower unit and the upper housing. This passage is just aft of the fwd mounting bolt. I just had the lower unit off to replace the driveshaft seals and shiftrod o rings. I also redid the w/p, all gaskets were replaced, the only part not renewed was the w/p upper housing. Because I'm new to outboards and I had been running the engine in a drum, I would not have noticed this water spraying out. Now, I flush the engine out in a shorter barrel in which the water just covers the water intake and now this passage is exposed. It seem like some of the exhaust pushes this water out? or just water pressure? There is no water in the lower gearcase, but this leads me to 2nd issue. As the engine sits on the stand I see a small amount of gear oil on the paper towel i place under it. It's not from the prop shaft seals, nor from the drain plug for sure, only by putting a clean paper towel in the exhaust outlet did I find where it came from. This is with the engine just sitting, and the lower unit was not over filled. I don't get it. I know now that there are a few of you that have these identical engines, Any ideas? I'd like to get to the stage where I can make more than 1 trip without a repair before the next trip. Apologize for the length, better to provide as much info up front to reduce the back and forth. Thanks to all, Jersey Bob
