jeffasmith
"I'm planning on disassemb
"I'm planning on disassembling the front half of the powerhead from the carbs to the crankcase split. For the Crankcase split I need either omc gel seal or loctite 518. The question is what gaskets should I be replacing. I believe my problem lies with the split crankcase, the previous owner worked on this and used the orange / red color make your own gasket and this crap has to go. The engine has a lean sneeze problem. The Carbs have been re-built with one size up orifices (I forget the number, might be 63) The sneeze problem still exists but in a smaller way than before the carbs were done. The fuel lines have been replaced and the VRO is disconeccted, Standard pump. The fuel connector has been bypassed, the fuel tanks and main hoses have been verified on another 1983 70hp also the fuel pump. The fuel lines have been replaced with clear ones so I could see what was and still is happening. The lines are getting air in them. I suspect this crankcase seal is the culprit. Your insights would be greatly appreciated. I might just be wasting my time with the crankcase seal but, I'm willing to give that a go before I dump this thing and just live with my 1983 70HP (about 62HP at the prop compaed to this other motor). Much appreciated! Jeff"
