1990 evinrude 200
romex
any ides on what would cause t
any ides on what would cause the crackshaft splines to rust away ? driveshaft good. motor runs like a champ but isn't turning lower unit or pumping any water
Crankshaft/driveshaft splines
Crankshaft/driveshaft splines rust away when someone does not install the upper driveshaft "O" Ring and grease the upper driveshaft splines thoroughly.
"I have been wondering what yo
"I have been wondering what you found out with this engine. Wished it had been better news. If the engine is otherwise in good shape, you may be able to get a shop to change out the crank without breaking the bank. I would closely inspect the top splines of the driveshaft before reusing it too. Good luck!"
