1990 evinrude 200 hp water pump
romex
"impeller looks new, how ever
"impeller looks new, how ever she pumped a small stream, then nothing out of the tell-tell hose. I pulled the t-stats and cover plates started the motor on the flusher an NOTHING. no water flow at all through the t-stat openings. ANY IDEAS ?"
"if meatal arms on flushette..
"if meatal arms on flushette...squeeze together ,to get as tight a seal,as possible....turn wtr on fully...ck hose for kinks etc....repl impeller.."
"yes , the water was on full b
"yes , the water was on full blast,seal tight,etc. guess i'm going to have to drop the foot again and take a look"
"the tube,that must slide back
"the tube,that must slide back,into,the wtr pump,hsng...pull the LU,look up,into the exhaust hsng,and there it is.....then,look at wtr pump,hsng,lg hole...they must be aligned....the wtr pump,pumps wtr,up,thru that tube,...u miss it,and it just blows wtr,in the exhaust hsng,...having,the results...u speak of........"
