Grandmalips
I am following up from a previous post:
I restored this motor and it will for the most part it will run well. However it will not cold start without starter fluid but once warm will fire right up on the first pull, also it will run great when I take it out and run it but after a long time at full throttle when I go to idle it will not idle and die. after that it will start back up again. Also the telltale does not seem to pee. Is the motor overheating? also I am at a loss to my cold start issues. Any thoughts or ideas would be great. Thank you
Things I have done:
Rebuilt Carb
New fuel
New spark plugs
checked impeller and re installed with fresh grease
Checked compression (90)
also the primer bulb squirts fuel into the carb so it is getting fuel
Any ideas?
Things I have done:
Rebuilt Carb
New fuel
New spark plugs
Any ideas?
