HydraulicBanana
Hi all, new to the forums here. I recently acquired a 90 ebbtide with a 305 alpha one. Plenty of automotive mechanical abilities here and a little on a previous boat or two I've owned years ago.
Impeller looks good, seems to have decent water flow when hooked to the hose. Top water hoses are cold, ones on bottom get hot. The person I got it from had it in the shop for overheating. They replaced the impeller, thermostat, gauge, and water pump and still overheats. The boat is in immaculate condition and worth the time and effort it will take to correct this issue, just not sure where to go from there with it.
I browsed a couple of posts before registering and saw where some were talking about the manifolds possibly being clogged and/or the shaft or bearing out the back needing greased. If anyone has experienced this before I could use all the advice I could get.
Thanks,
Thanks,
