jeffasmith
"New on the Suzuki discussion
"New on the Suzuki discussion board. I'm looking at picking up a used DT85. Here is all I know: one cylinder is low comp and it's still running, has pt/t. What does DT refer to? I've seen DF models mentioned. I'm an OMC guy so I'll ask related question like, is the VRO (OMC's version)similar, if so do many owners convert to standard fuel pumps and pre mix like OMC owners? Rebuild kits are they readily available? What is the approximate weight of this model? Anyone know if props from a 1983 70HP OMC would fit on this model (13 spline 14 x 17)? The 83' 70HP produces only 62HP at the prop and weighs in around 250lbs (with pt/t), so I'm hoping for a small gain in HP with little gain in weight. Your thoughts please! Thanks, Jeff"
