davewills4
"I have a suzuki DT140. my eng
"I have a suzuki DT140. my engine starts and runs fine, but after around 15 minutes when I open the throttle, it starts to lag and then cut out. After around 15 minutes it will be fine again until I opem the throttle and it starts to warm up. It will continue to run fine on tick over. I have replaces the water pump, gasgets, impeller, impeller key etc, put a new fuel pump kit on, but staill cant pin point the problem. It only seems to do it when I take it out on the water. I dont know if it is a fuel proble, mix problem or heat problem.
Any help would be real great.
Thank you.
Dave"
Thank you.
Dave"
