"Hi, the issue I am having wit
"Hi, the issue I am having with my motor is the warning horn sounds all the time when I start the motor. I had the water pump impeller replaced thinking that might be the problem but it still continues to sound. I checked the fuel filter, no problems there. Once in a while when I start the motor it does not alarm. The motor runs great and is not overheating,just makes that ungodly warning sound. One day I hit the throttle lever on top on the shifter control and it stopped. Is there a wire inside of the control case that could be loose? If so how hard is it to take it apart to cheheck it? Right now to make it quit I turn the key half way off until it stops but then that also shuts down the rest of my gauges."
