S
steve b
Guest
" I just had the head gasket r
" I just had the head gasket replaced by an outboard mechanic because my 90hp johnson was running rough, smoking alot, and oil was coming out of the upper unit area. The mechanic replaced the head gasket and i thought it would be fixed.
However, when i took it out last night it would very hard to start, had to be taken out of gear and reved for about 5 minutes before it finally settled down. Then when i would slow the boat of a plane it would stall. It used to run fine, but now its nearly impossible to keep running.
I think theres another problem but im not sure what it might be. The gas/oil is the same mix from my last trip where the boat ran fine, so i kinda elimate the feul supply.
It shakes the boat, and smokes alot, anyone got any advice as to what it may be? "
