1990 70 hp Yamaha
Oilcan
Have 1990 70 hp Yamaha 2 stroke that is extremely hard to start the first time. After once started it starts and runs fine. Have replaced spark plugs and pump fuel bulb numerous times. Seems like a fuel issue. Any suggestions would be appreciated.
Are using the correct starting procedure.----------Is the choke solenoid / enricher system working?----------On some motors you need to push in the key while cranking the motor over for starting.
Thanks for the reply racerone. Good thought. I believe the choke system is working. There is a separate switch near the key and I can hear the solenoid activate on the motor when I use the switch. Will remove the cover and verify the choke is really closing.
