The problem I have is that the motor will cut out with no warning,normally over 3000 rpm.It is instant,no splutter just dead. To get it going again I have to just touch the key and the motor will start, AFTER I let the key go.
I have cleaned out the carbies,they looked like new (motor has only done 95 hrs from new)
Replaced plugs.
Checked all fuel lines and connectors,replaced filter.
Checked all wires under flywheel ( for fraying,rubbing etc )
Compression is 105 on all cyls.
Is it possible I have a faulty Ignition Switch??
Out of the timer,stator or power pack,does one give more trouble than the other ?
Replaced plugs.
