1990 60 hp Evinrude
letsgo5
"Boat was running fine then wo
"Boat was running fine then would not crank. Rebuilt the starter, changed batteries and it cranked ran great turned off back on and back to no cranking. No noise nothing. I have power to the selenoid but no power from starter switch back to selonid. Any ideas??? THANKS Please help"
"There is a neutral safety swi
"There is a neutral safety switch incorporated within the control box. If you have power to the battery terminal of the ignition switch, I would suspect that this neutral safety switch is slightly out of adjustment.
Try moving the control (throttle/shift) lever back and forth slightly when turning the key to the start position.
If on the other hand, there is no voltage at the battery terminal of the ignition switch, I'd suspect that the main power fuse has blown for some reason. Fuse would be in one of the smaller RED wires leading from the starter solenoid.
When time permits, visit my store (copy/paste) at: stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
