First off, sorry for the long post that you are about to read, but I wanna try to explain in detail the issue with my outboard.
I changed my fuel filter(not the one attached to the motor).
Pumped the "fuel ball", and tried to start the motor...nothing. Removed the fuel line that is attached to the internal filter, then pump the ball until I got fuel up to the filter. Then I drained one of the pots on the carb, and again pumped the fuel to make sure I was getting fuel right to the carbs. Tried the motor...nothing.
Next, I poured just a little bit of fuel into the cylinder head, and the motor fired up right away. Let idle for about 10 min, shut off the motor, let it sit for an hour, tried the motor and it fired right away again.
So at this point I figure I had the fuel line air locked, and now after bleeding the fuel all is good. BUT I tried the motor again after about 5 hours of down time and nothing. Not even an offer.
I'm thinking I have a bad fuel pump, but I wanna see what you guys think before I go out and buy a new pump.
Thanks for your help
