N
neil baker
Guest
"Checking the throttle valve s
"Checking the throttle valve sensor on my 89 Suzuki DT85 today and it burned up. I was using the Clymer Suzuki manual and had the correct connections made. Black/red lead to power source, black lead to ground and green/red lead to the volt meter. I was using a variable power supply instead of the battery and it started smoking at about 9.5 volts. Any ideas as to why? Having a power problem with this motor, carbs, fuel pump and new fuel bulb and connector have helped some."
