1989 omc 23 stern drive
  • Thread starter Debbie Leach Devlin
  • Start date
D
Debbie Leach Devlin
Guest
"My hubby and friend are tryin
"My hubby and friend are trying to replace the gimble bearing. They have removed all screws and they can't get the stern drive off, they think the bearing ceased on the drive shaft any suggestions on what to do next? Help!!!!"
I have to ask a dumb question.
I have to ask a dumb question....Are they sure all the bolts are out? I ask this because I left two in and tried like hell to get the outdrive off.... check again. Ignore them if they look at you and say "of course they are all off"
What type drive are they worki
What type drive are they working on? Is it a Cobra? Did they unbolt the Hydraulic rams and remove the pivot pin? After that it should only be six locknuts and washers. Then it helps to support the unit with a hoist. If it's a Cobra a lifting eye can be screwed in where the oil dipstick goes-very top of the upper unit.
Yes all that was done and it s
Yes all that was done and it still will not come off it only moved about 1/4 inch out. Could the bearing be ceased on the drive shaft? If so what can be done? Yes it is a Cobra..hubby is ready to get rid of it!!!! Help!!! Thanks for your help.
You can lift the drive up and
You can lift the drive up and slide a block of wood in there and then let the drive fall against the wood to see if breaks free and then try standing/jumping on the drive so that it is pivoting against the wood.
