When the switch is turned on i have 3 short beeps. This i understand is normal. The motor has very little hours on it, but run it about 3 times per year since 2010. I do several times per year hook a flush fit to it and just run it for about 10 minutes. In 2010 launched the boat and started down the river and in about 2 minutes starting having short beep beep beep for about 2 miles to fishing hole. Soon as boat sits down beeping stops. Several days ago done the same thing. The water pump is shooting a steady stream of water, and lots of smoke is coming from exhaust when engine is running sitting still. The water pressure gauge goes up and holds there the entire time. All of a sudden the beeping came on and stay on until i pulled back on throttle and sat down. I moved around several times and never beep again. At the end of day i was 3 miles from ramp, fired motor up, water streaming out of hole and ran 45 mph all the way back to ramp, no beeping at all. Listed below are a few things i replaced on engine.
1. The wiring harness that goes to side of motor back to the small oil bottle on the engine. The cork gasket on this tank was cracked and the cap also. When this was replaced a fired the motor back up so oil would fill tank back up.
2. Water pump and impellar has also been replaced.
Any help would be appreciated.
