Hi everyone. I put the boat in the water last week and found it wasn't peeing when I started it up. I pulled it right out and took it home for tear down. The impeller was cracked and the impeller cup was deformed, actually bit into the driveshaft a little bit. I bought a new upper and lower impeller housing, impeller and all the fixins, going to see if I can get by without replacing the $450 driveshaft for the time being. My question to you is, the impeller seems to be much larger than the cup! There's probably an 1/8" if not more of overhang when you sit the impeller on top of the cup. That being said, is that normal? Do you have to squeeze the impeller into there and if so, which direction do you do so? Thanks!
