had this boat for 6 or 7 years now, so a little history
replaced alternator with an external kit ( 5 years ago),
engine water pump and seal and the cam slieve) and head gasket done carb replacement and rebuild (4 years ago),,
pertronix ignition and dist rebush (3 years ago),
out drive water pump, lower shift cable and drive shaft support bearing last year
So the issue i have is starting, i have to and expect to set the choke with the throttle and pump the throttle at least 3 times ( adds fuel with the accelerator pump)to get the engine to start cold, usual cranks about 15 seconds and fires up. it idles and runs well through out the entire rev range does not stumble or backfire. BUT when hot i have to pump the throttle 5 to 6 times and hold the lever almost fully opened to get it to start after about 20 seconds cranking, after start it idles normally ( about 700rpm) and runs fine.
so how do i cure the starting issues , any help would be much appreciated
thanks
chris
thanks
chris
