"Hi,
New to the forum and
"Hi,
New to the forum and need a few ideas on my 3.0l merc. It fouls the plugs but only when trying to go under power. Had a problem with the choke and it is wired open right now so it can't close. Then we took the boat back out and hit the throttle and the boat started to go and then died down. Started back up and same thing so turned around and went back in motor was running rough and barley made it back before it quite. Compression is good, new plugs, points, rotor, and cap. Timing is right on and steady. Idles good now choke is fixed and revs good. Just found a bad connection on the coil. Think that could do it? Usually I have no problem fixing a motor but this boat has been a nightmare since I bought it. It's a 17" Winner (Yea right a real winner). But the boats rides nice when it runs. Thanks for any input."
"Hi,
