mechaneer31
I have a 1989 Mariner 90hp 2 Stroke 3 cylinder outboard attached to a 16.5 foot Campion boat.
Issue: When on the water the motor will not perform correctly. With WOT boat speed maxes at 6-8 mph. Will not plane. Can throw water pretty far behind the boat though. When I bought the boat this issue has been there from the get-go. Did not know when I bought it cause running on muffs to make sure motor worked was not enough to know.
Current maintenance items being performed is replacing water impeller, refreshing lower unit gear oil.
Current fixes: Poppet valve is spitting water out from the valve last I had it on muffs trying to get it going for the season so I am replacing poppet valve, thermostat and temp sending unit wire.
Prop on boat is 13"d, 19P.
I talked to a local prop shop and they are recommending to verify the motor alignment with bottom of boat which I will do when the lower unit goes back on.
Mechanically, is there anything else I should be looking for or trying during my next lake trial to figure out what could be causing this problem?
