sdbasstracker
Motor ran crappy/idled rough last year (2012) and finally just would not start at all last fall. Mechanic finally got to it this spring. No spark, so replaced switch box and stator, did a tune-up, replaced fuel filter and lower unit maintenance. Motor now starts great, idles great, accelerates smooth to about 4500rpm then gets rough/makes a "knocking" noise and won't go any faster or higher rpm. Probably worth noting that 1st run off the dock it gets to about 5000rpm before acting badly, then after being shut down for fishing and restarted to make subsequent runs it gets to 4000-4500rpm before behaving badly. Prop and kit was replaced-which did make shifting into gear and accelerating smoother but did not really address the rpm problem. I am obviously not a mechanic but I would like to be able to talk to my boat mechanic about this in a constructive way. Anybody know what is causing this issue and how to fix it?
