Hey everyone just want to give thanks to everyone on here for helping out first of all. I’ve only posted a couple things but always get some good insight on the issues here.
Here we go: I’ve only had this 1989 bass tracker for about a month and it just started this up a couple weeks ago, the motor has been acting randomly odd today while fishing, run fine then die, the warming horn on the throttle control box went off. When I got home I popped the lid on the motor and smelled gas, it was definitely leaking. I instantly disconnected the fuel line and it stopped. I plugged the fuel line back in and primed the bulb and noticed there was gasoline leaking out from basically where the VRO unit mounts to the fuel pump. Now what I’m wondering is what is this a sign of? Is the fuel pump shot or is there a gasket that needs replacing? But I also noticed something funny on the oil line up to the VRO unit, I saw the spark arrestor in the line but noticed the actual oil line had no hose clamps on either end of the spark arrestor, but there clearly was at one point in time.. My manual states if there’s any leak in the vacuum for the VRO the motor will most certainly have problems and it should be addressed immediately. I’m gonna test the oil line, pull it off and prime the bulb to make sure oil is making it to the unit at least. Main question is the fuel pump gone or the VRO possibly out? They should definitely not be leaking fuel that’s for sure lol. Thanks for any advice!!
