I couldn’t find any direct answer reading some other posts but I just purchased an 1989 Bass Tracker and on it is a 89 Johnson 70HP motor. The starting battery looked a little rough and the guy I bought it from mentioned something about the cheap Atwood onboard charger not working for that battery, but I also thought the motor charges this battery anyways while running, but I’m a newbie to this. But I pulled it out to clean the terminals and noticed it’s the same exact battery as the one That controls the trolling motor. First time I’ve bought a boat like this so I don’t know much but the way I understood it there’s a cranking battery and a deep cycle battery to run electronics. The battery is an ever start 845MCA both say deep cycle power, the starting battery definitely looks a lot tougher than the other. I’d like to put a new cranking battery for the motor or at least sort out if it’s running the right batteries. It does start and run, only have had minor motor issues unrelated to the battery or electrical system.
