L
lloyd keast
Guest
"this engine runs great at low
"this engine runs great at low idle. At wfo it cuts out then comes right back on. I feel it is a fuel issue because i can hold the choke when it cuts out and it recovers. The cut out doesn't instantly cut, its more like it boggs down. I have checked for water,changed the plugs, changed fuel lines and filter, and replaced the bulb. both plugs are whitish grey. I ran carb cleaner through the last tank, and it made the problem worse. now it cuts/bogs at all throttle ranges. This outboard I have just puchased, and it has been in storage for two years. Does any one think that a simple acid bath carb cleaning and kit would solve the problem. Or is this something that is typical with the 40 hp vro? Also the VRO is disconnected I didn't want to mess withy it. I'm more comfortable mixing gas."
