I just bought this motor today, has 110#'s compression on both cylinders, started it up in a water barrel, pee line not peeing, checked for blockage in pee line, took off from exhaust manifold cover, no water. Had water 3 inches over pump pick up. Obviously the pump isn't working. How does the shift lever decouple? I have done other models, 78, 81, even an 88 225 hp, but not one of these. Doesn't the shift shaft screw into a brass collar? instead of being held in the older type brass / bronze clamps where the threads strip & you have to get the ball placed just right.
Seems like to me I read somewhere that you put it one of the gears, & count the number of turns you unscrew it.. I may be confused..
Please Help!!
Please Help!!
