SOAPSTONEARTIST
well I guess joe wants me to start a new thread as the one I was using was 11 months old. Still pertinent though and plenty of good advice from previous postings. The problem(s) I was having seem to tell me that my water pump impeller "might" be the cause. I also have to check all the ground connections to get the warning horn to work.
The problem was that while I was running at all speeds up to full throttle everything was working fine. Once I get to full throttle it would just bog down and I would have to reduce throttle speed to almost half. IF I stopped and turned it off for five minutes, everything would be fine again except that at full throttle the same thing would happen. At first I thought it might be fuel lines getting old and soft and restricting fuel flow so I replaced them all. I found out on this forum that it could possibly be the pump impeller wearing out ( as it's been 6 years since I last replaced it, along with the VRO pump) and things worked fine for five years until my current problem began. I have ordered a water pump kit and once that gets installed and I can test it I'll post my findings. Thanks for all the help...already!
