haffiman37
Silver Medal Contributor
"The restrictors direct how th
"The restrictors direct how the water flows through the cylinder and head to optimize and give EVEN cooling to all cylinders. Clean out all cooling channels and install new ones.
With regards to what You said about water leaking down the exhaus, there is one more possibility except the water tube and gaskets and that is a leakage in the exhaust cover gasket or corrosion hole in the plate '49'. Perhaps You should take down that as well when You are at it."
