J
Johnson1989
Guest
"This motor has been a bear.
"This motor has been a bear. This motor ran great first time in the water but alarm went off for overheating. We did a complete new water pump impeller ect. Also replaced the Tstats. Still had the overheat issue and replaced the Water reflectors. Overheat issue now is fixed. We took it out to test and it was bogging down and doesnt run barley at all. We didnt understand. It runs like a champ with the Cover off, as soon as you put it back on, or just set it on top it has no power. We double checked no wires pinched, no tubes being cut or pinched. Brought it back out and same deal. It runs great with the cover off but as soon as its on or even placed over it runs bad. Need Help her or suggestions.
Thanks~!"
Thanks~!"
