1989 J70TLCEM overheats
Have you verified the actual temp with an IR gun? Should read around 140-150F at the thermostat inlet at idle.
Are you running on muffs or in a barrel? To get correct reading you need to either have the boat launched or run with lower unit in a barrel with water level min 2-3" above split between gearcase and leg.
