K
Ken Spearing
Guest
"1989 GT150 (J150STLCEM
"1989 GT150 (J150STLCEM) [35 amp system] with powerpack, rectifier and stator assembly replaced 1 1/2 years ago won't crank. It gave trouble cold cranking a few times but once cranked, it would crank again easy as ever as long as warm then run strong like normal. Now it won't crank period. I get weak intermmitant spark at 2 cylinders. The stator ohms out good and I changed the powerpack out with an old one that is still good with no change. I also did a key switch elimination test with no change in spark behavior (also bypassed the kill switch just to be sure.) All wires look good. The one problem is when I did a sensor coil resistance test. All wires ohmed out except for the 'A' terminal on the starboard side which will only give infinity. I checked the wire a few inches back up from the connnector and got the same result. I shifted things around, turned it over and the resistance tested the same. Is is time to change the $350 timer base? I've been told by two mechanics it's rare to have an issue with one."
