mgrossbauer
I had no spark and found the flywheel magnet was loose. Removed flywheel, re-glued magnet in place where it appeared to be originally. Motor would not run right, started and idled OK, but had no power upon acceleration. Checked timing and found it way retarded, like a full 30 degrees from where it should be. Tried to adjust the trigger as far as I could, but timing marks are still about 20 degrees from the mark. Is this due to the magnet glued in the wrong position? How else could the timing be this far off? Any help would be appreciated.
