Hi all,
I accidently reversed the 12/14 AWG Grnd and +ve battery cables (the smaller ones) that supply power to the steering panel.
The thick 10 AWG battery cables (+ve and Ground) were connected correctly.
During that time, I kept trying to start the engin but nothing happened. Not realizing my mistake, I kept checking fuses under the strg panel, and must have turned the ignition key a couple of times.
Anyways, I have since then fixed my mistake, but now the engine turns over in spurts and does not start.
Would the incorrect battery connection have blown something?
Checked the starter and it works fine (disconnected from flywheel and tested)
Checked and cleaned the carb bowls, and they look good.
Checked spark plugs ( surface gap type) - they look okay.
Cleaned fuel filter.
How do I check the CD boxes, coils or spark?
Would the rectifier have blown and if so, does that affect starting? It is my understanding that, it only helps with charging the battery.
Any ideas on what I need to do next?
Appreciate the help.
CJ
Oops , forgot to include the model - Force 856X89F
CJ
