Sorry about not being clear. I'll start over. I have the omc manual and I have followed it to a T. Here is my problem. 1989 140 tx looper has a very rough idle until I get to about 1500 rpm's then it smoothes out and runs good all the way to WOT. I have rebuilt the carbs and inspected all of the ports and everything is clean. Replaced all of the fuel lines, Installed new fuel filter / water separator, checked primer, recirc system, compression, spark plug wires, stator, power pack, coils & thermostats. Everything has checked out within spec per the manual. When I tried to run throught the sync instructions (in the water under load) the idle timing was showing up as 4deg BTDC when it should have been around 8 deg ATDC. I had to back the idle timing screw almost all the way back to get it to be 8 deg ATDC and then it ran awful and wanted to stall. I was out of ideas and I thought that the port temp sensor could be bad causing the motor to stay in quick start mode until the RPM's went up. Per the manual it is a 10 deg advance which kinda makes sense.
The only thing that doesnt seem right is that I used a syringe to add fuel to each carb one at a time and they all bogged down except for CYL 1. I could add a lot of fuel and it wouldnt bog down at all. If I pulled the sparkplug wire it would barely run so I know the cyl was functioning.
Please let me know what I'm missing. I have twin motors and one is running fine so I have swapped all components to see if it fixes the problem with no luck.
