Thank you! Two seasons ago I acquired this motor with no history. A neighbor down the street passed away and his daughter sold off all his possession. The motor had only been registered to him for one year and never on a boat. I had a shop change out the trim motor and run through it. They did a link and sync, carb rebuild and water pump as well. They said the motor looked great and well taken care of compression numbers were 117-118 at that time. End of the first season the motor died at idle twice. In the water it would idle at 600-650 rpm and on the earmuffs on land around 1100 rpm.
This season I'm noticing more shutting off at idle about 1 in 8 times I'll stop but not right away after about 5 minutes of idle. Idle is 400-450 rpm in the water and 850-900 rpm on earmuffs on land. I double checked the notes from the shop and the timing was advanced and returned to factory when they had it.
On land on muffs it will not shut off at all only on the water. I was hoping it was something simple as the low speed adjustment. Everything else is perfect. I decarb the motor every year. And if I am near the helm I can blip the throttle a bit when I hear the idle getting a little rough and I am good for another 5 minutes.
