Hi All, I am new to the forum and need some advice (several questions so bear with me). I just purchased a 1989 Proline 17 cc with a 90 Evinrude. Had some problems getting gas from the inbaord tank (clogged anti syphon) anyway I was able to start the motor with an external tank and based on my limited knowledge I decided it would be best to run the carbs out of gas for the winter(I know that was not a good thing now) I fixed the gas line issue and primed the engine with the gas that was in the tank (year old gas I was told). Tried to start but could not get it to... So I figure the gas might be bad... Tried the external tank but still could not start it. In the process of doing this I always had to use 2 batteries in parrallel to get the engine to crank...and now the engine will barely crank so I belive I need a starter motor/solenoid. Thoughts on this? Also price of parts vary widely for what seems to be the right starter and solenoid. Does it make a difference if I go with the $90 starter or the ones costing upwards of $180? Also, is there a way to drain the carburator bowls without taking the carbs out as I believe that the gas in them is bad. I also noticed that the fusible link wire that attaches to the battery ( I believe to be part of the ignition wiring) is badly corroded and over heated (it was that way when I got the boat) Can I just buy one at a marina service center or can I get this on line some where (the wire nuts were sealed with silicon. Is there a special silicon for this purpose?). One more thing, I noticed that the steering wont turn the motor, Is there a way to adjust or free this up easily?
Thanks for any help and tips you can provide.
