"Ok I will give you the run do
"Ok I will give you the run down on this motor. I got it a couple weeks ago and the previous owner had disabled the VRO system, cutting and blocking the oil line. Thats fine.
Well when I got the motor it would perform inconsistent at WOT, it would surge. Sometimes run fine, and sometimes bog down.
I went ahead and rebuilt the 3 carbs and replaced all fuel lines. That didnt fix the problem.
I was suspecting a foul fuel pump, and I think its confirmed a dead fuel pump now. I can pump the primer bulb until its hard and the engine will start and run, but when the bowls run out of fuel, it dies, unless I pump them back up in the mean time.
What I want to do is just pull the VRO pump out and replace with a standard premix fuel pump.
I want to do this as cheap as possible and I have searched and searched on this topic and found mixed topics. I know I can use the 3 nipple fuel pump that supplied the 1983 model 70hp motors before VRO, but I really want an aftermarket part.
The price difference is huge. With that said my question is, is there a Sierra fuel pump that will work with my engine and work correctly?
also, is there anything else I may need to check that might be my problem instead of the fuel pump?
thanks"
thanks"
