"Bought a Stratos 289fs about
"Bought a Stratos 289fs about a year ago from a friend of mine, the boat has an Evinrude 200 vro on it. Up until about two weeks ago the motor ran fine. Recently though I had been having trouble starting motor until eventually it wouldn't start at all. I noticed a gas leak coming from a hose connected to the VRO. I am no mech. or good with motors, as many of you are so I had someone come to replace the hose as well as the ignition system. Upon replacing this he [the mechanic] was able to start the motor. However I am still unable to start the engine. Before starting I prime the bulb until "firm" and then turn the ignition while applying the choke at the same time, at times I will apply the throttle in the neutral position, generally at about 50%. The motor will crank but fails to start. I will usually continue to turn the ignition and apply the choke until upset at which point I raise the boat out of the water and go on with something else. What concerns me, besides the fact that the engine fails to start, is that when I raise the boat out of the water, gas/oil leaks out of the prop, what seems like a large amount at that. So my question is, Why wont my motor start, am I just going about starting it wrong, should i apply more/less throttle? Why is there gas/oil leaking out of the prop after failing to start the motor, is there a leak or am I flooding the motor? As stated earlier, I am no mechanic, just a person who loves to fish but cant afford a new boat or motor. Any help is greatly appreciated."
