1989 60HP VRO Tiller
ffever
My engine was converted to oil
My engine was converted to oil gas mixture before I bought it. I would like to convert it back because I don't like messing with mixing the gas. The engine is cutting out and running rough. When this is happening it runs better if I intermittently push the choke button. Some times it runs like new. I replaced the hose and bulb assembly that goes from the motor to the gas tank but it didn't seem to help much. I've seen other postings with similiar problems. I'm wondering if the problem could be my 12 gallon plastic tank? Any help would be appreciated!! What is involved in converting the motor back to oil injection? I just purchased manuals but haven't recieved them yet.
your best bet Is to do a thoro
your best bet Is to do a thorough check on this motor.Compression test and check to make sure that you have spark on each cylinder that will jump a gap of 7/16". Has this motor had the cooling system modification done??.As far as oil goes your best bet is to mix at 50:1.
