J
JIM JOHNSON
Guest
"WHEN YOU TURN THE IGNITION KE
"WHEN YOU TURN THE IGNITION KEY TO THE ON OR RUN POSITION THE TEMP ALARM SOUNDS EVEN WHEN THE MOTOR IS NOT RUNNING, IT IS PUMPING EXCELLENT WATER, IF YOU PLAY WITH THE KEY WHILE IT IS RUNNING THE ALARM WILL SHUT OFF, I THINK THE SWITCH MAY BE BAD, THE BOOK SAYS A STEADY SOUND MEANS OVER HEATING AND A PULSATING SOUND MEANS LOW OIL, THIS IS STEADY SOUND
ANY HELP WOULD BE GREAT"
