1989 60hp evenrude
jasonf
was on lake yesterday and it f
was on lake yesterday and it felt like i hit something with prop but i did not see any thing on my graph or with eyes i was in 40ft of water but moter ran rough took it to the boat shop and was told that it was the pinion gear but the boat goes into gear fine i dont have a clue please help
the pro had 1 of the blades be
the pro had 1 of the blades bent and what is the price on the pinion gears the guy told me that it was like 1100 dollars does that sound right
It sounds very high to me if a
It sounds very high to me if all you are getting replaced is the pinion..i would go as far as saying your getting ripped off take it to another pro.
If the pinion gear is damaged make sure you have the fwd gear replaced as well as the impact will have fractured a couple of teeth on the fwd gear
thanks for your help will take
thanks for your help will take your advice and take it to another pro what do you think getting that work done should cost
