minderaser
1989 24' searay cuddy 5.7 liter 260 hp Mercruiser Alpha I
Quick back ground on mechanics on lower unit. Found fluid a little milky end of 2008 season. I changed the fluid then stored and then in the spring of 2009 had the lower/upper seals changed along with impeller & all boots & Refilled with synthetic all done before dropping in water. I asked the mechanic a few different times to change my Gimble then but he insisted that it looked good as if it was just recently done. It ran all 2009 season no problems.
Ran about ten times this year so far and I checked the oil a week ago and it was clear and perfect looking. A couple days ago I started hearing a little clunck after shifting into gear but nithing to alarming. Went tubing yesterday no apparent problems. Took it out first thing today, got it up to speed then all of sudden engine bogged down as if I was towing a boat. So then I put in wake gear and stalled. Nuetral started up engine runs fine I take off it seems to be driving ok but then i smell gear lube burning and smoke (gear lube spraying on engine?) is coming from engine compartment.
I Look there is gear lube in my engine bay and it smells real bad. I was outside of the marina so I limped it back in and when I got to the dock it sounded pretty dry back there.
Then the really confusing part is water is now heard leaking in the back of the engine somewhere and I am taking on water making my bilge go off several times while it sits there waiting for me to retreive the trailor. When I got home I checked the fluid it was Milky Green...
I know I'm fricken heading back to the boat mechanic but can anybody give me an idea of what just happned to me and what I'm looking at for damages $....
