Hello All,
I have a 1989 Evinrude 48 Hp Special with Touch Trim. It appears that both the cable and cylinder are frozen. The end of the cable next to the actuator lever is broken off. Here is my question: How do I release the motor so I can tilt it up to trailering position? I want to replace the water pump and reseal the lower unit but I cannot get the ground clearance with the engine in the down position. I am able to remove the motor from the boat if necessary.
Thanks in advance for any and all help.
rcb13
rcb13
