1989 40 hp pinion bearing
seahag2
I'm going through a 40 hp '89 evinrude lower unit. I'm having trouble removing the pinion bearing from the case.Does any one have any experience with this? Thanks.
Re: 89 40 hp pinion bearing
Thanks for the quick reply. I got the bearing out tonight. Had to rig a puller. I see by my manual a special tool is required to determine the correct amount of shims to install when reassembling the pinion bearing/drive shaft/thrust bearing. Is there any other way to figure out the shims required? The old shims were destroyed when the thrust bearing gave up.
