1989 305 electronic ignition upgrade
ozzie54
"I have a 1989 larson hampton with a mercruiser 305, it has the original ign and I am considering upgrading to HEI. I have heard there may be a safety issue with gas fumes in the engine compartment due to the open coil compared to the original oil filled one. is this a concern is there a safe electronic ign available thanks"
"Ayuh,... An 89 should be the
"Ayuh,... An 89 should be the T-Bolt IV igntion...
It's the Best electronic igntion ever put on a boat motor...
What's to Upgrade,..??"
bondo why is it the best elect
bondo why is it the best electronic igntion? because the icm is almost 500.00 when you have to put a new in! just dont see it
"Thanks for the info, My ign i
"Thanks for the info, My ign is points and condenser and i want to upgrade to electronic, it doesnt have to be HEI that is just a cheap fix as it is readily available and easily changed, but I am not interested if it is possibly unsafe, I will check out the marine grade electronics"
