bill_w
Advanced Contributor
I ran this 1989 150hp Johnson motor all year, with no trouble, except the reg/rectifier wasn't working, so the battery didn't charge. Once I pulled the boat out for the year, I changed out the regulator/rectifier, and test ran it on a set of muffs. The motor is now charging, but while it was running on the muffs, near idle speed, it overheated on the port side. I know it was the port side because if i disconnected that temp sensor, the buzzer went off. Also, just from holding my hand on the block, there was a large temp difference between the port and starboard sides of the block.
There was a good stream of water from the 'pee' hole, and water was coming from all of the usual holes on the lower unit. So, why would it run great all year, then overheat after being out of the water for a couple of weeks? Could a thermostat have stopped working, and stayed in the closed position?
thanks in advance
Bill
thanks in advance
Bill
